some visitors are counted as separate visits even thou they hit the site at the same time. all visits (to different pages) were at exactly the same them and from the same ip address. How is this possible
if they were separate visits why weren’t they counted as return visitors
That is probably a display issue with the Live plugin, but we also fixed a bug with overcounting visits in 1.1.2b1 which you can download from: http://builds.piwik.org/piwik-1.1.2b1.zip
Sometimes one vistor reaches the site and viewed multiple pages. The IP-Adress is allways the same, but there are 2 entries in the live- and visitor-log.
In the table piwik_log_visit are two entries for the visitor. Every config-value is identical exept the “location_browser_lang”:
one entry is “de”, the other one is “de-de”.
It seems, the OS is always “WI7” and the browser is always “IE 8.0”.
Which config-values are used to get the config_id? Can I manually disable the location_browser_lang?
Does it happen very often? if not, it is possible that 2 users use same OS + browser + IP… yes, the language is used in the config_id, see line 1162 in core/Tracker/Visit.php
As I said, I have only 30-40 visitors per day. There is enough time between the visits, so I can very clearly say the entrys are from the same visitors.
Everything else is identical (IP, time, browser, OS, plugins,…).
And all double-entries are from different users, at least when I look at the detected city it looks so. They have only one in common: OS is Win7, browser is IE 8.0.
I use the PHP API, maybe there is a fault in getting the @$_SERVER[‘HTTP_ACCEPT_LANGUAGE’]
I will cut out the location_browser_lang. I seems the better way, at least for my purpose.
