RHEL CentOS installation
If you already have a CentOS + LAMP installation, skip to “Piwik installation” below.
Note All commands should be run as root
CentOS minimal installation
  • Install CentOS 6.6 (tested here: from minimal ISO – CentOS-6.6-x86_64-minimal.iso)
  • Enable networking by default at boot: the /etc/sysconfig/network file should contain the following line:
NETWORKING=yes
  • The /etc/sysconfig/network-scripts/ifcfg-eth0 file should contain the following lines:
DEVICE=eth0
BOOTPROTO=dhcp
ONBOOT=yes
  • If SSH server is enabled, make sure to setup public-key authentication and harden as per best-practices/local environment policies require (IP whitelisting, custom port/port-knocking, fail2ban, etc).
Avoid slow SSH connections caused by GSSAPI authentication. In /etc/ssh/sshd_config comment out all GSSAPI* options
Other required utilities
yum install wget unzip
Installing the rest of the required LAMP environment (Apache web server, MySQL, PHP)
  • Install the Apache web server, MySQL database server, PHP5 and recommended extensions:
Note consider installing PHP 5.6 as it has important bug fixes related to memory management and performance which greatly improves Piwik’s stability.
yum install httpd mysql-server php php-mysql php-mbstring php5-curl php5-gd php5-cli php5-geoip php-pdo php-xml -y
  • Start the web and MySQL servers:
service mysqld start
service httpd start
  • Configure services to start automatically at boot:
chkconfig httpd on
chkconfig mysqld on
  • Finish configuration of the MySQL server (root credentials and initial setup):
/usr/bin/mysql_secure_installation
By default only port 22 (SSH) will accept connections in CentOS. Firewall rules are needed to open requests to ports 80 and 443.
In CentOS 6:
iptables -I INPUT 5 -i eth0 -p tcp –dport 80 -m state –state NEW,ESTABLISHED -j ACCEPT
service iptables save
In CentOS 7.0:
firewall-cmd --permanent --zone=public --add-service=http
firewall-cmd --permanent --zone=public --add-service=https
firewall-cmd --reload
Piwik installation
Database setup
  • Setup a “piwik” user, create the database and corresponding permissions:
mysql -uroot -p
Enter password:
mysql> CREATE USER ‘piwik’@’localhost’ IDENTIFIED BY ‘password';
Query OK, 0 rows affected (0.00 sec)
mysql> GRANT ALL PRIVILEGES ON piwik_db.* TO ‘piwik’@’localhost’ WITH GRANT OPTION;
mysql> flush privileges;
Query OK, 0 rows affected (0.01 sec)
mysql>
mysql>Bye
  • Go to the Apache root document directory:
cd /var/www/html/
  • Get the latest Piwik release and uncompress it:
wget http://piwik.org/latest.zip
unzip latest.zip
  • Set permissions for Piwik directories:
chmod 777 ./piwik/config
chmod 777 ./piwik/tmp
  • Open the Piwik login web page on your server and login to complete the setup steps:
http://[ipaddress]/piwik/
The setup steps are described in the 5-minute Piwik installation guide.
For whoever needs to read this last tip:
If your server is running CentOS, SELinux or Redhat Enterprise Linux (RHEL), and you run into permissions problems, you may need to specify “context”. So fix the issue with the following commands:
chcon -R -t httpd_sys_rw_content_t /path/to/matomo
semanage fcontext -a -t httpd_sys_rw_content_t "/path/to/matomo(/.*)?"
This is a useful guide for anyone setting up Matomo on an older CentOS server. The step-by-step commands make it easy to follow, especially the LAMP and database setup. Just keep in mind that some of the versions and commands are outdated now.
