[RESOLVED] Test of 2.3.0-rc3 and theme
I use the old theme (called ExampleTheme) with piwik. After the migration to 2.3.0-rc3 (from 2.2.x) i have now the ExampleTheme is now the new theme with the old logo.
We don’t have the old theme. (I have some user that are disturbed by the theme change).
Thanks.
The old theme should stlil be here, if you disable “ExampleTheme” it will be shown.
However please note that we will soon remove the old theme from piwik, so we can focus on one theme only. This is discussed in Remove Zeitgeist theme from Piwik and support only Morpheus · Issue #5222 · matomo-org/matomo · GitHub
Thanks,
I advert my user that soon, there is no other choice that change.
