Hi
I am trying to save a custom user preference through the API.
This is my code:
function save_http()
global $_HTTP;
//$_HTTP is an array like $_REQUEST
//Export to string for storage
$_HTTP = var_export($_HTTP, true);
$request = new Piwik_API_Request
method=UsersManager.setUserPreference
&userLogin=$_SESSION[User]
&preferenceName=LastHTTP
&preferenceValue=$_HTTP
&token_auth=1e84fb673b0a8ce77b6fdd16af0493d3
&format=json
$result = $request->process();
I keep getting this back:
Fatal error: Uncaught exception ‘Zend_Exception’ with message ‘No entry is registered for key ‘config’’ in D:\UniServer\www\dashboard\piwik\libs\Zend\Registry.php:147
Stack trace:
#0 D:\UniServer\www\dashboard\piwik\core\Piwik.php(160): Zend_Registry::get(‘config’)
#1 D:\UniServer\www\dashboard\piwik\core\Piwik.php(197): Piwik::isHttps()
#2 D:\UniServer\www\dashboard\piwik\core\DataTable\Renderer\Json.php(78): Piwik::overrideCacheControlHeaders()
#3 D:\UniServer\www\dashboard\piwik\core\DataTable\Renderer\Json.php(30): Piwik_DataTable_Renderer_Json::renderHeader()
#4 D:\UniServer\www\dashboard\piwik\core\API\ResponseBuilder.php(130): Piwik_DataTable_Renderer_Json->renderException()
#5 D:\UniServer\www\dashboard\piwik\core\API\Request.php(125): Piwik_API_ResponseBuilder->getResponseException(Object(Zend_Exception))
#6 D:\UniServer\www\dashboard\utils.php(239): Piwik_API_Request->process()
#7 D:\UniServer\www\dashboard\index.php(321): save_http()
#8 {main}
thrown in D:\UniServer\www\dashboard\piwik\libs\Zend\Registry.php on line 147
Any ideas?
I can use the setUserPreference for other things such as defaultReport but it appears it doesn’t like me using a custom preference?
