Reset goals
#1
Created some goals, noticed my regex’es were not 100% correct (are they ever?) and udpdated them. However, the goal panel still shows the results from the old goal regex’es.
How do I refresh / reset the goal data so it correctly displays the latest goal changes?
(Yes, I can delete and recreate, but I was thinking there was something more elegant)
Also - How do you make goals “retroactive” that is, apply the goal to previous days?
Thanks.
(Matthieu Aubry) #2
Unfortunately it is not possible at this stage, but would be a nice feature.
#3
It’s been some time now. Is it possible to do that now?
Console command maybe?
