Reports for a site loaded in iframe
Reports for a site loaded in iframe show only the page url which contain the iframe. ,
So, site A contains a site B loaded in a iframe. Site B include piwik.js and piwik tracking code, with the right siteId. Any click on site B inside the iframe is visible via Visitors in Real Time widget, but when I’m looking at details per visitor I can see only the url for site A which contain the iframe, times X (X being the number of clicks inside the iframe). Numbers of clicks are correct. url recorded is not.
loading the site from the iframe as a stand alone site works fine and I can see all the data I want.
Any hint will help. Thanks
Hi there,
ifyou think this is a bug in piwik, could you create an issue at: Issues · matomo-org/piwik · GitHub ?
it would be great if you can submit a little HTML snippet that lets us reproduce the bug, and if you explain what you get VS what you expected to get.
Hi Matt.
Thanks for your answer. I’m not sure if this is a bug, however, I’ll investigate more, time permitted.
I am also not sure if this is a bug but I can give you an example:
We host the site A on which the JS tracking code is integrated.
When there is a request on an external website via an iframe, e.g.: http://lingro.com/translate/http:/.../A/PATH/armut.html this shows up in our Piwik statistics, see lingro.com.png as a reference.
As I debugged this case, I found out that there may be another problem/bug:
On the site The Global Labour University: Scholarships there is a link to our website. We see the path /161.html of the original link in Piwik, please refer to the second attachment called global-labour-university.org.
REMINDER (20150810); sorry for that but pressure from work.
is there any new knowledge about this issue?
Cheers
