I’m new to matomo and I’m trying to figure out two things regarding searching and filtering for existing reports (I’ve seen that you can create custom reports with a non-free plugin - that is not what I mean).
Searching
There is a search bar that allows you to search the report at the bottom of the report. How can I move this to the top?
It’s not useful at all to have a report of 100 rows (example) and if you want to search you have to scroll down all the way. That’s bad UI and it took me a long time to even find this. -
Searching
Searching the pages report if it’s not in flat mode a search with the full path does not lead to any results. If I put it in flat mode it does give result.
Example:
I’d like to find all pages with path /abc/def/xy and below. Entering “/abc/def/xy” in the page report (not in flat mode) gives no results. I have to first switch to flat mode and than I can search. Why? -
Searching
Having changed the view mode to the flat version and doing a search - can I somehow save that search (as a bookmark or somewhere else). So I can send that search to someone else? -
Drill down
In the “not flat” page report. Is it possible to click on a node and have this as the new topmost node in the report? Again it would be nice to bookmark this.
5 Filtering
Is there any means of filtering an existing report? Knowing Google Analytics and eTracker I’m a bit confused as I can do “nothing” with a report.
Example: I’d like to know how many people use a certain browser for certain pages and how this interacts with session parameters (like number of viewed pages).
Best regards,
Sebastian
