Hey everyone. I have followed the instructions for removing the Piwik footprint from the javascript code here:
http://piwik.org/faq/how-to/#faq_132
But now Piwik does not seem to be tracking anything.
I modified the piwik.php file with the URL of the site to track, and the user token for the user I created.
I verified that my server is using PHP5 with “allow_url_fopen = On”
Not sure what the problem is… It was working fine until I started changing the javascript following the instructions from the FAQs to remove the footprint.
Nobody can help with this??
matthieu
(Matthieu Aubry)
October 13, 2011, 1:45am
#3
please try debugging the tracking calls as per instructions in: Tracking API - Analytics Platform - Matomo
maybe you will see the problem looking with Firebug
Thanks I will take a look and see if I can figure this out. I appreciate your help.
xipe
October 13, 2011, 5:48am
#5
Tried this too, followed the instructions.
After that, I couldn’t even open my Piwik server any more:
Fatal error: Out of memory … for the include files
Restoring the old piwik.php and returning to the old tracking code was the only option to get Piwik running again.
Is this a known error and how could I get around it?
Cheers,
xipe
Sooo its years gone by now, and im still only using piwik on a couple of my sites because of this footer footprint…
I havent been able to fix it yet… Does anyone know how to do this yet?!?
I just followed the most recent version of how to remove the footer footprint and ive got
Invalid variable type ‘NULL’, expected one of following: Piwik_DataTable
on all of the sites that I’ve done it on .
I checked the php.ini,
I modified my footer code,
I updloaded the piwik.php to the tracked sites
I dont see what is wrong.
matthieu
(Matthieu Aubry)
February 16, 2013, 3:44am
#8
if you follow instructions it should work, if you need pro help: http://piwik.org/consulting/#contact-consultant
I followed the instructions, and it shows errors.
I am now trying the wordpress plugin and enabling the feature that way, I dont know if it’s working or not yet.
