If I check the box # “Regularly delete old raw data from the database” in “Privacy/ Anonymize data”, first it works:
- Delete logs older than (days) appears and I can define “90 days”
- SAVE , it seems it works, system is aking for passphrase
- System answer is green: “Settings updated.”
Everything is fine so far, but after refreshing the page, the settings are cleared… no checkbox, no days, just empty.
BUT all the other settings in “Privacy/ Anonymize data” like “Anonymize Tracking Data” or “Delete old aggregated report data” are working and can be changed any time.
