A great feature might be to allow editing the config for separate DB connections for Writes (Create, Insert, Update, etc…) from Reads (Select).
We have a couple servers set up to handle the DB with replication. Unfortunately, our (psuedo) Slave still needs write permissions to handle things like session storage, dashboard changes, etc… In the interim, I removed the tables that the UI updates from the Master to avoid breaking replication.
Would be great to have something like the following in the config:
Would you like to contribute an improvement to this FAQ and add your setup, which I think is different? are there special mysql settings to avoid some piwik tables from replication? can this be a feature of piwik or somehow documented etc.?
I’ll take a better look at the docs you linked and see what we’d be able to contribute. I’m a little hesitant to recommend our configuration only because its fairly new and I definitely don’t think I’ve had enough data to justify it. I believe there is a lot of value for Piwik to allow multiple database connections and in turn replication, but would like to get a better proof of concept.
My goal was to transition from our legacy in-house tracking platform to Piwik, which was far more robust. Therefore, I needed to allow for tracking of 30+ sites, 500k or more page views a day, with the real challenge of keeping reporting as close to real-time as possible. We are hosting with Amazon and we already had a couple dedicated database servers to work with, so I had set up three databases. A Master, Archive, and Slave. The idea was to separate external (tracking) connections, from overhead caused by the archiving process, from our own internal connections.
I created a solution yesterday for switching between a Master and Slave (or defaulting to the standard database connection if a master is not specified). So far, it appears to be working - however the only thing I am not sure about is how it effects Profiling and how it effects the event hooks. Can you have more then one object tied to a single Hook (ie Reporting.createDatabase)? As for Profiling, I believe those functions would need to be rewritten to also check if a master db was set and either displaying each database connection independently, or aggregating the Profiling data?
just found your message regarding splite read writes to different servers.
Although it’s an old topic, do you still have this setup.
We have a 3 three server cluster with one master.
Our idea is to send all write queries to the master and all read queries to a load balancer for the three server.
