We’d like to track about 5 million actions per day. We have more than 200,000 items in the queue according to ./console queuedtracking:monitor
and it’s not getting fewer (at least not enough - the queue generally works, but we just have too many requests to track it seems?).
We’re using MySQL. Is my understanding correct that switching to Redis would not help, as the slow parts seems to be to put the data into MySQL (i.e. not the queue table, but the final table)?
In the settings under “Number of queue workers” it says “Be aware you need to make sure to start the workers manually.” Starting manually means calling ./console queuedtracking:process
, doesn’t it?
It always just prints:
Starting to process request sets, this can take a while
This worker finished queue processing with 0req/s (0 requests in 0.01 seconds)
So we’re still at 1 worker. Increasing the number in the settings (web UI) doesn’t help, ./console queuedtracking:monitor
still says 1 workers active
Any idea what we’re doing wrong? Our server has 8 cores and its load is about 3-4.
According to top, the load is spread like this (%CPU
column:)
60% mysql
60% php-fpm7.2
20% nginx
Output of ./console queuedtracking:test
Settings that will be used:
Backend: mysql
NumQueueWorkers: 1
NumRequestsToProcess: 25
ProcessDuringTrackingRequest: 1
QueueEnabled: 1
Redis backend only settings (does not apply when using MySQL backend):
Host: 127.0.0.1
Port: 6379
Timeout: 0
Password:
Database: 0
UseSentinelBackend: 0
SentinelMasterName: mymaster
Version / stats:
PHP version: 7.2.24-0ubuntu0.18.04.1
Uname: Linux analytics 4.15.0-66-generic #75-Ubuntu SMP Tue Oct 1 05:24:09 UTC 2019 x86_64
Backend version: 5.7.27-0ubuntu0.18.04.1
Memory: array (
'used_memory_human' => 'disabled',
'used_memory_peak_human' => 'disabled',
Performing some tests:
Connection works in general
Initial expire seems to be set correctly
setIfNotExists works fine
expireIfKeyHasValue seems to work fine
Extending expire seems to be set correctly
expireIfKeyHasValue correctly expires only when the value is correct
Expire is still set which is correct
deleteIfKeyHasValue seems to work fine
List feature seems to work fine
Done
