I have enabled “purge old logs” in the privacy settings but it seems that nothing happened. The job should have been run this night. How can I check the job or manually start it from the command line?
The job is working.
I think the problem ist the limitation that only 1000.000 entrys will be deleted each run. That´s only a small part of my data. So I have to change the purge settings every day. That´s not very comfortable.
How can I delete all data older than 2010 in one run?
I would like to delete all data older than 01.01.2010. So I have to calculate the days from 01.01.2010 until today. In one run only a part of the data will be deleted because the maximum is 1000.000 entrys. So the next day I have to change the number of days in the settings. If I don´t change the settings it will delete data younger than 01.01.2010.
My job was running several days an now all data older than 01.01.2010 is deleted. The archive_blob tables from 2009 are empty., but there are still entries in the archive_numeric tables from 2009. As you can see in the attachement. Why were they not deleted?
