quick question, I have the archive-processing cronjob running. Now, form my understanding, when I enable “Purge old visitors logs” it should make no difference for the data shown in the frontend, is that correct?
At least as long as the reports were processed by the cronjob…
If you purge old visitor logs, then you will lose the visitor raw logs, so the Visitors > Overview will show “no data” for those dates that were deleted.
