I would expect that every hour the statistics would be updated. But this doesn’t appear to be happening. I can also fire the archive process from the command prompt, and it outputs the XML, but the XML is the same every time I call the script.
Am I possibly misunderstanding something? Any information would be greatly appreciated!
Thanks for a great project!!! style_emoticons/<#EMO_DIR#>/smile.gif
[quote=matthieu @ Mar 31 2010, 02:09 PM]60 means 1min here, you would want to write 3600
the data should be updated, in the output of archive.sh, every time_before_today_archive_considered_outdated seconds. Does it work?[/quote]
It does not appear to work (update stats) — even running with time_before_today_archive_considered_outdated = 0, it shows the same output as displayed by the UI prior to running the command, meaning it doesn’t appear to actually do anything but display the previously calculated statistics. Running archive.sh multiple times also outputs the same XML.
Any thoughts about what might be wrong would be appreciated! Thanks. style_emoticons/<#EMO_DIR#>/smile.gif
Are you able to try the new Piwik from SVN?
you can download at: http://dev.piwik.org/trac/changeset/2078/t…&format=zip
This bug might be fixed with the new timezone implementation. I would be interested to know if it now works for you. thx
The new version (rev=2096) does work, but not to 100%.
The first time archive.sh is called, the current data are written for today. However, the script called again (45 minutes later), then no change is made (time_before_today_archive_considered_outdated = 600). The statistics are still on the values from the first call.
Sorry about my english
ok, it is a problem with the last rev=2084. “Unknown column ‘visit_server_date’ in ‘field list’” This field was deleted by the last rev…
