have an similar problem, only the notice is different:
Notice: Object of class Piwik_Date to string conversion in /var/www/vhosts/blogschatz.de/httpdocs/piwik/libs/Zend/Db/Statement/Mysqli.php on line 208
If I switch the date from yesterday to today, the error occurs.
My PHP Version: 5.1.6
Here is the full backtrace:
Backtrace -->
#0 Piwik_ErrorHandler(8, Object of class Piwik_Date to string conversion, /var/www/vhosts/blogschatz.de/httpdocs/piwik/libs/Zend/Db/Statement/Mysqli.php, 208, Array ([params] => Array ([0] => ssssssss,[1] => 62,[2] => 1,[3] => Piwik_Date Object ([] => 1273017600,[] => UTC),[4] => Piwik_Date Object ([] => 1273017600,[] => UTC),[5] => 1,[6] => 2010-05-05 16:53:25,[7] => done,[8] => 2),[stmtParams] => Array ([0] => ssssssss,[1] => 62,[2] => 1,[3] => Piwik_Date Object ([] => 1273017600,[] => UTC),[4] => Piwik_Date Object ([] => 1273017600,[] => UTC),[5] => 1,[6] => 2010-05-05 16:53:25,[7] => done,[8] => 2),[value] => 2,[k] => 8)) called at [(null):0]
#1 mysqli_stmt->execute() called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/libs/Zend/Db/Statement/Mysqli.php:208]
#2 Zend_Db_Statement_Mysqli->_execute(Array ([0] => 62,[1] => 1,[2] => Piwik_Date Object ([] => 1273017600,[] => UTC),[3] => Piwik_Date Object ([] => 1273017600,[] => UTC),[4] => 1,[5] => 2010-05-05 16:53:25,[6] => done,[7] => 2)) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/libs/Zend/Db/Statement.php:300]
#3 Zend_Db_Statement->execute(Array ([0] => 62,[1] => 1,[2] => Piwik_Date Object ([] => 1273017600,[] => UTC),[3] => Piwik_Date Object ([] => 1273017600,[] => UTC),[4] => 1,[5] => 2010-05-05 16:53:25,[6] => done,[7] => 2)) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/libs/Zend/Db/Adapter/Abstract.php:468]
#4 Zend_Db_Adapter_Abstract->query(INSERT IGNORE INTO piwik_archive_numeric_2010_05 (idarchive, idsite, date1, date2, period, ts_archived, name, value)
VALUES (?,?,?,?,?,?,?,?), Array ([0] => 62,[1] => 1,[2] => Piwik_Date Object ([] => 1273017600,[] => UTC),[3] => Piwik_Date Object ([] => 1273017600,[] => UTC),[4] => 1,[5] => 2010-05-05 16:53:25,[6] => done,[7] => 2)) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/PluginsFunctions/Sql.php:41]
#5 Piwik_Sql::query(INSERT IGNORE INTO piwik_archive_numeric_2010_05 (idarchive, idsite, date1, date2, period, ts_archived, name, value)
VALUES (?,?,?,?,?,?,?,?), Array ([0] => 62,[1] => 1,[2] => Piwik_Date Object ([] => 1273017600,[] => UTC),[3] => Piwik_Date Object ([] => 1273017600,[] => UTC),[4] => 1,[5] => 2010-05-05 16:53:25,[6] => done,[7] => 2)) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/PluginsFunctions/Sql.php:86]
#6 Piwik_Query(INSERT IGNORE INTO piwik_archive_numeric_2010_05 (idarchive, idsite, date1, date2, period, ts_archived, name, value)
VALUES (?,?,?,?,?,?,?,?), Array ([0] => 62,[1] => 1,[2] => Piwik_Date Object ([] => 1273017600,[] => UTC),[3] => Piwik_Date Object ([] => 1273017600,[] => UTC),[4] => 1,[5] => 2010-05-05 16:53:25,[6] => done,[7] => 2)) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/ArchiveProcessing.php:634]
#7 Piwik_ArchiveProcessing->insertRecord(Piwik_ArchiveProcessing_Record_Numeric Object ([name] => done,[value] => 2)) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/ArchiveProcessing.php:567]
#8 Piwik_ArchiveProcessing->insertNumericRecord(done, 2) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/ArchiveProcessing.php:428]
#9 Piwik_ArchiveProcessing->initCompute() called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/ArchiveProcessing.php:409]
#10 Piwik_ArchiveProcessing->launchArchiving() called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/Archive/Single.php:185]
#11 Piwik_Archive_Single->prepareArchive() called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/Archive.php:170]
#12 Piwik_Archive::build(1, day, 2010-05-05) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/plugins/UserSettings/API.php:41]
#13 Piwik_UserSettings_API->getDataTable(UserSettings_browser, 1, day, 2010-05-05) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/plugins/UserSettings/API.php:72]
#14 Piwik_UserSettings_API->getBrowser(1, day, 2010-05-05) called at [(null):0]
#15 call_user_func_array(Array ([0] => Piwik_UserSettings_API Object (),[1] => getBrowser), Array ([0] => 1,[1] => day,[2] => 2010-05-05)) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/API/Proxy.php:147]
#16 Piwik_API_Proxy->call(Piwik_UserSettings_API, getBrowser, Array ([method] => UserSettings.getBrowser,[format] => original,[filter_limit] => 5,[filter_sort_column] => nb_uniq_visitors,[filter_sort_order] => desc,[module] => UserSettings,[action] => getBrowser,[idSite] => 1,[period] => day,[date] => 2010-05-05)) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/API/Request.php:113]
#17 Piwik_API_Request->process() called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/ViewDataTable.php:341]
#18 Piwik_ViewDataTable->loadDataTableFromAPI() called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/ViewDataTable/HtmlTable.php:75]
#19 Piwik_ViewDataTable_HtmlTable->main() called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/Controller.php:153]
#20 Piwik_Controller->renderView(Piwik_ViewDataTable_HtmlTable Object ([] => ,[arrayDataTable] => ,[] => CoreHome/templates/datatable.tpl,[] => 1,[] => Array ([enable_sort] => 1,[filter_sort_column] => nb_uniq_visitors,[filter_sort_order] => desc,[filter_limit] => 5),[] => Array ([show_goals] => ,[show_search] => ,[show_table] => 1,[show_table_all_columns] => 1,[show_all_views_icons] => 1,[show_export_as_image_icon] => ,[show_exclude_low_population] => ,[show_offset_information] => 1,[show_footer] => 1,[show_footer_icons] => 1,[apiMethodToRequestDataTable] => UserSettings.getBrowser,[uniqueId] => UserSettingsgetBrowser),[] => 0,[] => ,[] => getBrowser,[] => UserSettings,[] => ,[] => UserSettings.getBrowser,[] => ,[] => Array ([label] => Browser,[nb_visits] => Besucher,[nb_actions] => Aktionen,[max_actions] => Maximale Aktionen bei einem Besuch,[sum_visit_length] => Von Besuchern verbrachte Gesamtzeit (in Sekunden),[nb_uniq_visitors] => Eindeutige Besucher,[nb_actions_per_visit] => Aktionen pro Besuch,[avg_time_on_site] => Durchschnittszeit auf der Seite,[bounce_rate] => Absprungsrate,[revenue_per_visit] => Wert pro Besuch,[goals_conversion_rate] => Besuche mit Konversionen),[] => Array ([0] => label,[1] => nb_uniq_visitors),[period] => day,[otherPeriods] => Array ([1] => week,[2] => month,[3] => year),[periodsNames] => Array ([day] => Array ([singular] => Tag,[plural] => Tage),[week] => Array ([singular] => Woche,[plural] => Wochen),[month] => Array ([singular] => Monat,[plural] => Monate),[year] => Array ([singular] => Jahr,[plural] => Jahre)),[isDataAvailable] => 1), ) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/plugins/UserSettings/Controller.php:73]
#21 Piwik_UserSettings_Controller->getBrowser() called at [(null):0]
#22 call_user_func_array(Array ([0] => Piwik_UserSettings_Controller Object ([] => UserSettings,[] => 2010-05-05,[] => Piwik_Date Object ([] => 1273017600,[] => UTC),[] => 1,[] => Piwik_Site Object ([] => 1),[] => Array ([label] => General_ColumnLabel,[nb_visits] => General_ColumnNbVisits,[nb_actions] => General_ColumnNbActions,[max_actions] => General_ColumnMaxActions,[sum_visit_length] => General_ColumnSumVisitLength,[nb_uniq_visitors] => General_ColumnNbUniqVisitors,[nb_actions_per_visit] => General_ColumnActionsPerVisit,[avg_time_on_site] => General_ColumnAvgTimeOnSite,[bounce_rate] => General_ColumnBounceRate,[revenue_per_visit] => General_ColumnValuePerVisit,[goals_conversion_rate] => General_ColumnVisitsWithConversions)),[1] => getBrowser), Array ()) called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/core/FrontController.php:129]
#23 Piwik_FrontController->dispatch() called at [/var/www/vhosts/blogschatz.de/httpdocs/piwik/index.php:59]
