I have a problem with the “Page Titles” dashboard widget. If I click on “NEXT >” or on a column header to sort or try to change the number of lines I only get the animated graphic and “Loading data…” but nothing more. – I don’t have these problems with the other widgets.
What’s wrong?
My Piwik installation runs on Apache/2.2.15 with PHP 5.4.17.
While creating a test user for you I have noticed that the problem does only occur with my old superuser login but not with a new user. – Deleting the contents of the /tmp folder didn’t solve the problem.
