There are some problems with locales in translations files.
First in “Norwegian Nynorsk”: the locale is empty
Second in “Belarussian”: the locale is the same as russian
Thanks for all!
Thanks for all!
Hi
if you can submit patch to correct erroneous locales, it would be great style_emoticons/<#EMO_DIR#>/wink.gif please create aticket if you have a patch
