As I am newer to MATOMO, I automatically updated today to version 4.0.3.
Two issues I am having now:
1-) In the Administration panel (General Settings) I only have two items in the menu:
- PERSONAL (Email & SMS reports)
- PLATFORM (Widgets, API and Glossary)
all other menu like System check are gone.
2-) Even when the real visitor information is there, I have the message “There is no data for this report.” in other visitor reports.
I appreciate any help.
Regards,
Camps
UPDATE about issue 1: I cleared the Matomo cache using ./console cache:clear, and now all the settings are visible from the Administration menu.
UPDATE about issue 2: the visitor map widget is stuck in a fixed visitors number previous the update. The message “There is no data for this report." is gone.
