problem with tracking code and tracking on firefox
I’m new and I’m just starting to use Matomo, so be indulgent
I installed the tracking code with the plugin available for Joomla. After verification, the code is not visible in the source of the pages of my website, that is good, but that is normal?
I tested the tracking and I see my tracking, except Firefixe 60 Mac with which I have no tracking ??? cookies are not installed, but I have accepted them.
In other browsers no problem?
Nevermind, i got the same problem. Firefox users are not tracked It works very well with others browsers.
I tried differents configurations of the tracked code but without success.
Maybe recents version of Firefox are not tracked anymore ?
I found that my firefox had the tracking protection enabled, even if the protection seems disabled in firefox’s preferences.
I had to disable it in about:config (privacy.trackingprotection.enabled).
I understand, but a visitor is not going to change his config when he visits a website … tracking is wrong, because visitors using Firefox will not be counted!
There are no solutions?
I found your tracking code. It gets moved into this js file.
But I am getting really many CSP-errors in Firefox on your site. Is it possible that your CSP is not working in Firefox and therefore Matomo gets blocked.
I check, the website is on Joomla. I installed the “rfrPiwik” plugin recommended by Matomo and I copied the provided JS script. I just checked.
In the source I just have the comment of the script at the bottom.
I looked at the statistics in Matomo, I had a follow up today …
I also copy / paste the JS script into the index.php in the tag. Same situation, except that the comment is at the top of the page …
actually, I saw these errors and I think I know how to solve them.
Regarding Matomo’s JS script, I understood where my source display problem came from. I use JCH Optimized to compress JS files, must I find how to remove it from the compressed file …
by deactivating JCH Optimized, in the tools of developments of Chrome> Network, I found a file “piwik.js” which comes since my Matomo … but I can not extract it from JCH Optmized, I will contact their support!
