Problem with Segments
Hello, I have a problems with Segments.
I will create a segment to filter the visits with Direct view AND only 1 page view.
This is my rule:
Action In Visits - Greater than = 1
AND
Channel Type - Is not = direct
This seems to be not working correctly.
Look at
Acquisition → All Channels → Channel Types →
Direct Entry:
without segment: 611 visits
with segment: not present
but
**Search Engines: **
without segment: 2,429 visits
with segment: 652 visits
It filtered more than the segment specifications.
This is also considered in the Visits per number of pages
without segment: 2,181 visits
with segment: - visits
It filtered also ALL visits with only 1 visit action. That is not the rule.
Hi @melbao
Don’t you want, with this rule exclude these visits (then exclude visits “direct” with one single page view)? Then, if there is 2 page views (regardless of the origin) or if the channel type is not direct (regardless of the number of actions), you’ll see the visit. I think you have to make a table with these cases to check the segmented visits…
Yet it works as expected. But i had checked it yet only as a “Test”.
