Hi guys,
sorry for staying persistent but I still have an annoying problem with one line of code introduced in Piwik 2.0.1.
In Commit make sure log class is loaded · matomo-org/matomo@63bc449 · GitHub you added
require_once 'Log.php';
to core/Error.php in response to Ticket #4398[/url]. I assume that your intention was to include Log.php from Piwik core, but instead this line of code is including Log.php from /usr/share/php (see http://www.php.net/manual/en/ini.core.php#ini.include-path for details). This will cause errors as described in [url=http://dev.piwik.org/trac/ticket/4403]Ticket #4403, 301 Moved Permanently and 301 Moved Permanently .
A simple solution would be to change the mentioned line to
require_once PIWIK_INCLUDE_PATH.'/core/Log.php'.
Or do you realy need the Log.php from the PEAR package as some others are assuming?
Best,
Benjamin
