First, sorry if I am duplicating any existing post about this topic. But I already searched forum but couldn’t find any related answer. May be I am overlooking.
My problem is, I am successfully can set the custom variables but unable to track them and getting results in Piwik admin. Here is my Piwik javascript implementation code.
var _paq = _paq || [];
(function() {
var u=(("https:" == document.location.protocol) ? "https" : "http") + "://[piwikurl]/";
_paq.push(['setSiteId', 1]);
_paq.push(['setCustomVariable', 1, 'VisitorType', '<?php echo isMember() ? 'Member' : 'Non-Member';?>', 'visit']);
_paq.push(['setCustomVariable', 2, 'RoleType', '<?php echo roleType();?>', 'visit']);
_paq.push(['trackPageView']);
var d=document, g=d.createElement('script'), s=d.getElementsByTagName('script')[0]; g.type='text/javascript';
g.defer=true; g.async=true; g.src=u+'piwik.js'; s.parentNode.insertBefore(g,s);
As I already mentioned that I can see these custom variables under “Visitors -> Visitors Log”. But when I go to “Visitors -> Custom Variables”, there is no tracking data against the custom variables.
I am not sure the problem is in the following code or somewhere else:
Here are my results from Piwik admin: http://content.screencast.com/users/haroon.allshore/folders/Jing/media/c1ab063b-4ce7-47be-8944-cfe36301f04c/2014-05-19_1956.png
Do I need to make any changes in Piwik settings? Do I need to call “trackPageView” after setting each custom variable.
PS: I am using Piwik 2.2.2.
