Problem of db encoding!
Hi
I’m trying to migrate Matomo to a new server but I have an issue with the db. Matomo on new host complains about that:
## **SQLSTATE[HY000] [2019] Unknown character set**
I have tried using PHPMyAdim to change the character set of tables and columns and updating config file in same time but it still keeps giving that error message. I have tried utf8_unicode_ci, utf8_general_ci and same with utf8mb4 but still same error :frowning:
New server is running MariaDB 10.4 and PHP 8.2
Thankr for help,
Vincèn
No one on that ?
Thanks
did you try reinstalling MariaDB through SSH?
I had something similar, not same error, but had to update MariaDB.
Did a cleaner install, cleared cached too.
MariaDB is working perfectly fine (it’s on a shared hosting server).
I found the solution by using differenc character set for data and collations:
charset = "utf8"
collation = "utf8_unicode_ci"
Edit: it worked few minutes and now it makes a new error, just a nightmare to fix that thing :frowning:
## **SQLSTATE[42000] [1253] COLLATION 'utf8_unicode_ci' is not valid for CHARACTER SET 'utf8mb4'**
Vincèn
I think your issue might be with the Shared Hosting.
The collation utf8_unicode_ci is valid only for the utf8 character set, not for utf8mb4, which is often the default in modern MariaDB/MySQL installations.
On shared hosting servers you may not have access to the configuration files (i.e.my.cnf) to globally set the character set and collation. Instead, you’ll need to explicitly set the character set and collation in your database, tables, or connection code.
I’d reach out to the hosting support regarding this.
I’ve never seen this error and I use only private VPSs, my own ones or for clients.
PS: What you can do to check what I said above is to run the following SQL query to check the server defaults:
SHOW VARIABLES LIKE 'character_set%';
SHOW VARIABLES LIKE 'collation%';
This will show the default character set and collation for the server. If the default is utf8mb4, you’ll need to adjust your configuration to match.
PPS: I’ve found myself personally tweaking things with MariaDB and getting it to work smoother with lots of back and forth terminal commands, taking notes etc. I suggest you try, reach out to support and let us know how you go.
@metrprime sorry for late answer. Regarding the shared hosting, I have no problem to setup an instance on it with Matomo installed from their control panel.
I can modify charset and collation of all Matomo tables/db through PHPMyAdmin but I can’t find a combination working (modifying in same time matomo config file of course).
I thought to use utf8_unicode_ci for everything but then Matomo tells it’s an unknown character set :frowning: What do you use as default encoding for both tables and collations ?
here are results of the shared hosting server but which couple should I use that will work with Matomo ?
Screenshot_20241130_170636
Screenshot_20241130_170643
Well I finally found out the couple that works :partying_face:
CHARACTER SET utf8mb4
COLLATE utf8mb4_general_ci
Got my Matomo back working immediately once all tables updated in PHPMyAdmin and Matomo config file updated :wink:
Excellent that u got it working, yay!
This will be helpful for other Matomo users too, thanks for updating with the solution!
