Problem IP Uruguay
Hi, There is problem with the IP of Uruguay , interprets piwik ip 186, 190 and 200 as a country Spain .
Here is a list of IP range Uruguay extracted from IP Range: IP Country, IP Ranges, Find IP Location - IP Address Country
46.36.198.236 - 46.36.198.240
164.73.0.0 - 164.73.255.255
170.51.64.0 - 170.51.127.255
179.24.0.0 - 179.31.255.255
186.8.0.0 - 186.8.255.255
186.48.0.0 - 186.55.255.255
186.122.65.0 - 186.122.65.255
190.0.128.0 - 190.0.159.255
190.64.0.0 - 190.64.255.255
190.99.96.0 - 190.99.111.255
190.108.0.0 - 190.108.31.255
190.112.52.0 - 190.112.55.255
190.112.202.0 - 190112202255
190.132.0.0 - 190 135 255 255
192.146.237.0 - 192146237255
200.0.88.0 - 200.0.88.255
200.0.204.0 - 200.0.207.255
200.2.32.0 - 200.2.63.255
200.3.12.0 - 200.3.15.255
200.7.84.0 - 200.7.87.255
200.10.60.0 - 200.10.63.255
200.12.155.0 - 200.12.156.255
200.35.153.0 - 200.35.153.255
200.40.0.0 - 200.40.255.255
200.58.128.0 - 200.58.159.255
200.61.83.128 - 200.61.83.191
200.71.0.0 - 200.71.31.255
200.81.35.0 - 200.81.35.255
200.93.240.0 - 200.93.247.255
200.108.192.0 - 200108255255
200.115.64.0 - 200.115.79.255
200.124.192.0 - 200124223255
200.125.0.0 - 200.125.63.255
201.217.128.0 - 201217191255
201.219.224.0 - 201219255255
201.221.0.0 - 201.221.63.255
Piwik uses external IP database from http://www.maxmind.com/ as far as I know, so maybe you should contact them.
Are you sure that the problem isn’t simply that you have Piwik’s GEOLocate feature configured with the default setting?
The default uses the browser’s Preferred Language configuration to guess at the user’s location. If this is so, someone in Uruguay whose browser is set to US English would be identified as coming from the USA. Spanish = Spain, UK English = United Kingdom, German = Germany, etc.
