I am trying to install Piwik on a Linux based shared hosting platform (Fasthosts). I am getting an issue with:
always_populate_raw_post_data=-1
To prevent some critical issue, you must set the following in your php.ini file: always_populate_raw_post_data=-1
After making this change, restart your web server.
I have added this line to the php.ini file in the root directory. I also tried the user.ini file, but everything try it doesnt recognize it. I’ve spoke to the host and they suggested adding it to the htaccess file but that just returns a 500 internal server error.
Have I missed anything?
Thanks!
