Problem Goal Naming of Matomo for computed fields
Hi
The problem in a computed field in looker studio is that matomo sends the goal name with quotation marks. So if my goal in Matomo is Download Whitepaper, Matomo will list the Conversions of the Goal Name like this in Looker Studio: “Download Whitepaper” Conversions.
Why do you send quotation marks with the goal name. Because of the quotation marks, I cannot create a computed field like this:
Sum(“Download Whitepaper” Conversions)
The quotations marks gives an error in the computed field.
Can you help?
Thx for your support.
Hi Everyone
Any Answer from the Matomo Team? Because you link to this Forum in your FAQ for the Matomo Looker Studio Plugin.
I can see why this is frustrating, especially if the quotation marks are being added automatically by Matomo. It would be helpful if the goal name came through as plain text so it could be used directly in Looker Studio formulas. Hopefully someone can clarify if there’s a workaround or fix for this.
The quotes are likely coming from the Matomo connector itself. Don’t include them manually in the formula—select the field from the available metrics instead. If needed, use a calculated field to strip the quotes first.
