hey!
i have a little problem.
I tried trunk 1472 and today again the actual one.
GeoIP is working, but shows only “Unknown” instead of cities and sometime instead of the country “UserCountry_country_–”
i tried the newest version of GeoIP.
i tried to solve the problem with the “geoipUpdateRows.php” but got this error:
Notice: Use of undefined constant PIWIK_USER_PATH - assumed 'PIWIK_USER_PATH' in /users/theo/www/piwik/core/Piwik.php on line 89
Notice: Use of undefined constant PIWIK_USER_PATH - assumed 'PIWIK_USER_PATH' in /users/theo/www/piwik/core/Piwik.php on line 91
Piwik # open source web analytics
Piwik couldn't write to some directories.
Try to Execute the following commands on your Linux server:
chmod 777 PIWIK_USER_PATH/tmp
chmod 777 PIWIK_USER_PATH/tmp/templates_c
chmod 777 PIWIK_USER_PATH/tmp/cache
If this doesn't work, you can try to create the directories with your FTP software, and set the CHMOD to 777 (with your FTP software, right click on the directories, permissions).
After applying the modifications, you can refresh the page.
If you need more help, try Piwik.org.
* Piwik homepage
* Piwik Frequently Asked Questions
* Piwik Documentation
* Piwik Forums
* Piwik Online Demo
Warning: require_once() [function.require-once]: open_basedir restriction in effect. File(Zend/Exception.php) is not within the allowed path(s): (/users/theo/temp:/users/theo/www) in /users/theo/www/piwik/libs/Zend/Registry.php on line 146
Warning: require_once(Zend/Exception.php) [function.require-once]: failed to open stream: Operation not permitted in /users/theo/www/piwik/libs/Zend/Registry.php on line 146
Fatal error: require_once() [function.require]: Failed opening required 'Zend/Exception.php' (include_path='../../../core:../../../libs:../../../plugins') in /users/theo/www/piwik/libs/Zend/Registry.php on line 146
i set the tmp-folders to 777 and deleted the cache, nothing happend.
any idea?
thanks!
EDIT: 0.4.3 is not working for me! we couldn´t solve the problem with this version…only the trunks are working.
