Problem connecting looker studio connector with matomo/wordpress
Hello.
I’m trying to connect looker on a matomo for wordpress with the official connector, but it doesn’t work.
Following the documentation, I have:
  • unblocked password authentication in the plugin config.ini
  • created a dedicated user XXX in wordpress for the connection
  • generated for this user a token YYY for an application ZZZ
Then I tried to connect looker with:
  • user: {website url}/wp-content/plugins/matomo/app
  • token: ZZZ:YYY (but I also tried XXX:YYY)
But in all cases, I get the message:
Sorry, your credentials have been sent, but they are invalid.
What did I forget or do wrong?
Thank you for your help.
[edit: I also tried to switch the role of XXX from “matomo view” to “matomo write”, and even “Matomo super admin” to test, but no luck]
Did you save the Token after you created it?
