style_emoticons/<#EMO_DIR#>/dry.gif
This long text above are showing up after that I log in to admin panel.
Hope you can guide me to right direction style_emoticons/<#EMO_DIR#>/wink.gif
Warning: fopen(): SAFE MODE Restriction in effect. The script whose uid is 0 is not allowed to access /var/www/piwik/tmp/assets owned by uid 33 in /var/www/piwik/core/AssetManager.php on line 137
Backtrace →
#0 Piwik_ErrorHandler(2, fopen(): SAFE MODE Restriction in effect. The script whose uid is 0 is not allowed to access /var/www/piwik/tmp/assets owned by uid 33, /var/www/piwik/core/AssetManager.php, 137, Array ([mergedContent] => html,body,div,span,applet,object,iframe,h1,h2,h3,h4,h5,h6,p,blockquote,pre,a,abb
r,acronym,address,big,cite,code,del,dfn,em,font,img,ins,kbd,q,s,samp,small,strike
,strong,sub,sup,tt,var,b,u,i,center,dl,dt,dd,ol,ul,li,fieldset,form,label,legend,
table,caption,tbody,tfoot,thead,tr,th,td{margin:0;padding:0;border:0;outline:0;fo
nt-size:100%;vertical-align:baseline;background: transparent;}form {margin:0px;}body{line-height:1.33;background-color: white;color:black;}ol,ul{list-style: none;}blockquote,q{quotes: none;}label{cursor:pointer;}:focus{outline:0;}ins{text-decoration: none;}del{text-decoration: line-through;}br.clearAll{clear:both;height:0;line-height:0;font-size: px;}br.clear,div.clear{ clear:both;height:0px;overflow:hidden;}body{font-family:Arial,Verdana,A…
font-family: Arial, Helvetica, sans-serif;
color:#5e5e5c;
font-size:14px;
line-height:24px;
padding:0px 20px 15px 0;
#feedback-faq strong, #feedback-sent strong {
color:#5e5e5c;
#feedback-faq ul, #feedback-sent ul {
list-style:none;
padding:0 0 0 20px;
font-size:12px;
line-height:18px;
#feedback-faq a, #feedback-sent a{
color:#5176a0;
text-decoration:none;
font-weight:bold;
#feedback-error {
color: red;
text-align: center;
border: 2px solid red;
background-color:#FFFBFB;
margin: 10px;
padding: 10px;
#feedback-success {
color: #38D73B;
text-align: center;
border: 2px solid #38D73B;
margin: 10px;
padding: 10px;
#feedback-form { font-size:12px; line-height:18px;}
#feedback-form label{ float:left; width:135px; padding:4px 15px 0 0; text-align:right; position:relative; }
#feedback-form label i{ font-style:normal; color:#cbcbcb; }
#feedback-form br{ clear:both; }
#feedback-home{ float:left; margin:-7px 0 0 20px; }
.ui-dialog .ui-widget-header{ background:none; border:0; font:bold 18px Arial, Helvetica, sans-serif; color: #7e7363; clear:both;},[baseDirectory] => …/…/plugins/Feedback/templates/,[hashcode] => f600a8fab30fe233a6a00bdfbdb879d6,[newFilePath] => /var/www/piwik/tmp/assets/f600a8fab30fe233a6a00bdfbdb879d6.css))
#1 fopen(/var/www/piwik/tmp/assets/f600a8fab30fe233a6a00bdfbdb879d6.css, w) called at [/var/www/piwik/core/AssetManager.php:137]
#2 Piwik_AssetManager::generateMergedCssFile() called at [/var/www/piwik/core/AssetManager.php:95]
#3 Piwik_AssetManager::getMergedCssInclude() called at [/var/www/piwik/core/AssetManager.php:63]
#4 Piwik_AssetManager::getCssAssets() called at [/var/www/piwik/core/SmartyPlugins/function.includeAssets.php:36]
#5 smarty_function_includeAssets(Array ([type] => css), Piwik_Smarty Object ([template_dir] => Array ([0] => /var/www/piwik/plugins,[1] => /var/www/piwik/themes/default,[2] => /var/www/piwik/themes),[compile_dir] => /var/www/piwik/tmp/templates_c,[config_dir] => configs,[plugins_dir] => Array ([0] => /var/www/piwik/core/SmartyPlugins,[1] => /var/www/piwik/libs/Smarty/plugins),[debugging] => ,[error_reporting] => 30719,[debug_tpl] => ,[debugging_ctrl] => NONE,[compile_check] => 1,[force_compile] => ,[caching] => 0,[cache_dir] => /var/www/piwik/tmp/cache,[cache_lifetime] => 3600,[cache_modified_check] => ,[php_handling] => 0,[security] => ,[secure_dir] => Array (),[security_settings] => Array ([PHP_HANDLING] => ,[IF_FUNCS] => Array ([0] => array,[1] => list,[2] => isset,[3] => empty,[4] => count,[5] => sizeof,[6] => in_array,[7] => is_array,[8] => true,[9] => false,[10] => null),[INCLUDE_ANY] => ,[PHP_TAGS] => ,[MODIFIER_FUNCS] => Array ([0] => count),[ALLOW_CONSTANTS] => ,[ALLOW_SUPER_…
Warning: fopen(/var/www/piwik/tmp/assets/f600a8fab30fe233a6a00bdfbdb879d6.css): failed to open stream: No such file or directory in /var/www/piwik/core/AssetManager.php on line 137
Backtrace →
#0 Piwik_ErrorHandler(2, fopen(/var/www/piwik/tmp/assets/f600a8fab30fe233a6a00bdfbdb879d6.css): failed to open stream: No such file or directory, /var/www/piwik/core/AssetManager.php, 137, Array ([mergedContent] => html,body,div,span,applet,object,iframe,h1,h2,h3,h4,h5,h6,p,blockquote,pre,a,abb
nt-size:100%;vertical-align:baseline;background: transparent;}form {margin:0px;}body{line-height:1.33;background-color: white;color:black;}ol,ul{list-style: none;}blockquote,q{quotes: none;}label{cursor:pointer;}:focus{outline:0;}ins{text-decoration: none;}del{text-decoration: line-through;}br.clearAll{clear:both;height:0;line-height:0;font-size: px;}br.clear,div.clear{ clear:both;height:0px;overflow:hidden;}body{font-family:Arial,Verdana,Arial,Helvetica,s…
color:#5e5e5c;
font-size:14px;
line-height:24px;
color:#5e5e5c;
list-style:none;
padding:0 0 0 20px;
font-size:12px;
line-height:18px;
color:#5176a0;
font-weight:bold;
#feedback-error {
color: red;
text-align: center;
margin: 10px;
padding: 10px;
#feedback-success {
color: #38D73B;
text-align: center;
margin: 10px;
padding: 10px;
The file : can not be opened in write mode.
