Plugins.matomo.org over https
Hi everyone.
We are starting using Matomo in out organization to unify various statistics scattered all over the place. It works great so far. Thanks.
We are experiencing a little problem while connecting to plugins.matomo.org . For some reason, matomo uses http to initiate connection, which is blocked by our proxy server:
curl -Is https://plugins.matomo.org/
HTTP/1.1 200 Connection established
HTTP/2 200
date: Fri, 28 Jul 2023 06:08:03 GMT
server: Apache
# curl -Is http://plugins.matomo.org/
HTTP/1.1 403 Forbidden
Date: Fri, 28 Jul 2023 06:08:07 GMT
Content-Type: text/html
Cache-Control: no-cache
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
Content-Length: 3677
X-Cache: MISS from proxy
X-Cache-Lookup: MISS from proxy:8080
Via: 1.1 proxy (squid/3.5.20)
Connection: keep-alive
We would want to use https from the start. Is there a setting in config.ini for that? So far I put host and port in [proxy] section of config.ini.php . I simply changed:
return 'http://plugins.matomo.org';
to:
return 'https://plugins.matomo.org';
in plugins/Marketplace/config/config.php file and it works, but I am afraid that I will forgot about it during an upgrade. I also triggers file integrity check warning.
Thank You.
I just found about this - https://github.com/matomo-org/matomo/issues/19081 . I guess will be migrating to 5 as soon as possible. Which is fine.
Hi @lpcezgovpl, Matomo 5 will use https by default for requests to plugins.matomo.org, but in the meantime you can change the api_service_url config setting to make Matomo 4.x do the same.
[General]
api_service_url = https://api.matomo.org
@bx80 Thank You. We’ll do it right away.
