Hello people,
I just installed WordPress clean while setting up a new project and used some extra security inside my .htaccess file to block bots and other trouble.
Most people who know WordPress will also know this Firewall code.
5G Firewall by Perishable Press
# 5G FIREWALL
# 5G:[QUERY STRINGS]
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteCond %{QUERY_STRING} (environ|localhost|mosconfig|scanner) [NC,OR]
RewriteCond %{QUERY_STRING} (mod|path|tag)\=\.?/? [NC,OR]
RewriteCond %{QUERY_STRING} boot\.ini [NC,OR]
RewriteCond %{QUERY_STRING} echo.*kae [NC,OR]
RewriteCond %{QUERY_STRING} etc/passwd [NC,OR]
RewriteCond %{QUERY_STRING} \=\\%27$ [NC,OR]
RewriteCond %{QUERY_STRING} \=\\\'$ [NC,OR]
RewriteCond %{QUERY_STRING} \.\./ [NC,OR]
RewriteCond %{QUERY_STRING} \: [NC,OR]
RewriteCond %{QUERY_STRING} \[ [NC,OR]
RewriteCond %{QUERY_STRING} \] [NC]
RewriteRule .* - [F]
</IfModule>
# 5G:[USER AGENTS]
<IfModule mod_setenvif.c>
SetEnvIfNoCase User-Agent ^$ keep_out
SetEnvIfNoCase User-Agent (casper|cmsworldmap|diavol|dotbot) keep_out
SetEnvIfNoCase User-Agent (flicky|ia_archiver|jakarta|kmccrew) keep_out
SetEnvIfNoCase User-Agent (libwww|planetwork|pycurl|skygrid) keep_out
<Limit GET POST PUT>
Order Allow,Deny
Allow from all
Deny from env=keep_out
</Limit>
</IfModule>
# 5G:[REQUEST STRINGS]
<IfModule mod_alias.c>
RedirectMatch 403 (https?|ftp|php)\://
RedirectMatch 403 /(cgi|https?|ima|ucp)/
RedirectMatch 403 (\=\\\'|\=\\%27|/\\\'/?|\)\.css\()$
RedirectMatch 403 (\,|//|\)\+|/\,/|\{0\}|\(/\(|\.\.\.|\+\+\+|\|)
RedirectMatch 403 \.(cgi|asp|aspx|cfg|dll|exe|jsp|mdb|sql|ini|rar)$
RedirectMatch 403 /(contac|fpw|install|pingserver|register)\.php
RedirectMatch 403 (base64|crossdomain|localhost|wwwroot)
RedirectMatch 403 (eval\(|\_vti\_|\(null\)|echo.*kae)
RedirectMatch 403 \.well\-known/host\-meta
RedirectMatch 403 /function\.array\-rand
RedirectMatch 403 \)\;\$\(this\)\.html\(
RedirectMatch 403 proc/self/environ
RedirectMatch 403 msnbot\.htm\)\.\_
RedirectMatch 403 /ref\.outcontrol
RedirectMatch 403 com\_cropimage
RedirectMatch 403 indonesia\.htm
RedirectMatch 403 \{\$itemURL\}
RedirectMatch 403 function\(\)
RedirectMatch 403 labels\.rdf
</IfModule>
Well after all this installing is complete i try to install Piwik inside a folder on my Root of the hosting and i get this error before installing Piwik!
Everything else is green and checked only for this message.
Could somebody please help me and give me a solution to Whitelist Piwik?
Or will this only be an install problem?
What if i delete the G5 Firewall code from my .htaccess file for just a few minutes, - > install Piwik and after the installation is completed i restore back my G5 Firewall code would that also solve this problem or not?
Meanwhile thanks,
