I had some problems disabling the cookie of Piwik. In the end I switched from using piwik.js to /js/index.php, which solved the problem. Maybe this is something the Piwik-team should look into?
Code that was not working:
var pkBaseURL = (("https:" == document.location.protocol) ? "https://analytics.yyy.nl/piwik/" : "http://analytics.yyy.nl/piwik/");
try {
var piwikTracker = Piwik.getTracker(pkBaseURL + "piwik.php", 1);
piwikTracker.disableCookies();
piwikTracker.trackPageView();
} catch( err ) {}
</script><noscript><p><img src="http://analytics.yyy.nl/piwik/piwik.php?idsite=1" style="border:0" alt="" /></p></noscript>
Code that works:
document.write(unescape("%3Cscript src='" + pkBaseURL + "js/' type='text/javascript'%3E%3C/script%3E"));
try {
} catch( err ) {}
