Hi, I have 2 issues:
1.
I did installed Pwik 1.12 few months ago, all works fine, but when I try to import logs manually through importlogs.py, it removes statistics for $(BINGDATE - 1 day).
For example, if I have statistics till 5 Jan 2014, I want to import logs from 6 Jan to 9 Jan. I run script
importlogs.py --idsite=1 --recorders=16 --url=http://example.com/piwik/ /var/log/apache2/access_log
with access log file containing queries from 6 to 9 January. Then, run archive.php. After this go to Piwik, and what we see? Correct statistics till 4 Jan, ZERO visits for 5 Jan, and correct visits from 6 to 9 Jan 2014. This problem did not disappeared after update to Piwik 2.0.2
Like the same as first issue:
Log rotate set up to rotate logs weekly, yesterday I recovered statistics from all my archive access_log’s in Piwik. But today, there is no any visits from 4 Jan till today, but they was imported by me yesterday. If this can help you to solve problem, current log file begins at 05 Jan 03AM.
Server info:
RHEL 6.4 x86_64 with latest updates;
Piwik installed to its owned directory, running at Apache 2.2.15 (backend), nginx 1.4.1 at frontend, MySQL (Percona) 5.5.31-30.3;
