Piwik using MS SQL
Does piwik support any other database apart from mysql. We need to get it to work with MS SQL as we have all our database consolidated into one server and are using MS SQL.
I have seen in the trunk that there are references to other database, but they are all commented out. I am using the latest version downloaded from this website and not the trunk and when we try and activate them, it throws errors.
Would appreciate if someone knew what the status was and if there is any support for other databases.
Thanks,
Rakesh
Anyone knows if this feature is still in development ?
Best regards
Hi there,
Please check the FAQ: How do I use another database like Postgresql, SQLite, Oracle? Will you support Nosql databases like Hadoop, Mongodb? - Analytics Platform - Matomo
