Hi, The solution to this is likely very obvious however I cannot find it. My website is showing on the website frontend as at version 1.10.1. I have recently downloaded the newest PIWIK release and followed the upgrade instructions below ( upgrading using the manual upgrade path)
All documents unzipped correctly using the -o overwrite option, I then browsed to my Piwik site in a web browser and there was no notification to say that an upgrade is required as described in the upgrade guide.
I then attempted to force the database to upgrade manually using the command console core:update.
I received the following message in shell
*** Update ***
Database Upgrade Required
Your Piwik database is out-of-date, and must be upgraded before you can continue.
Piwik database will be upgraded from version 2.7.0 to the new version 2.9.1.
The following dimensions will be updated: log_visit.config_browser_engine.
The database upgrade process may take a while, so please be patient.
Done!
Piwik has been successfully updated!
My Piwik website is still showing as it was previously with all the old PIWIK branding and version numbers
Additionally when i click on check for upgrades I recieve the following Java error:
The string CoreHome_YouAreUsingTheLatestVersion_js was not loaded in javascript. Make sure it is suffixed with _js and that you called %7BloadJavascriptTranslations plugins=’$YOUR_PLUGIN_NAME’%7D before your javascript code.
Can you assist me in resolving these issues with the upgrade?
My version.php file is showing the latest release
const VERSION = '2.9.1';
