A long time ago i installed piwik, and sometimes i check the statistics.
After a long time not visiting the piwik-panel now I got following massage:
Declaration of Piwik_Log_APICall::log() should be compatible with that of Piwik_Log::log()
in '/www/htdocs/USER/DIR/tools/piwik/modules/Log/APICall.php' at the line 52
#0 Piwik_ErrorHandler(2048, Declaration of Piwik_Log_APICall::log() should be compatible with that of Piwik_Log::log(), /www/htdocs/USER/DIR/tools/piwik/modules/Log/APICall.php, 52, Array ()) called at [(null):0]
#1 Piwik::createLogObject() called at [/www/htdocs/USER/DIR/tools/piwik/modules/Piwik.php:873]
#2 Piwik::createLogObject() called at [/www/htdocs/USER/DIR/tools/piwik/modules/FrontController.php:311]
#3 Piwik_FrontController->init() called at [/www/htdocs/USER/DIR/tools/piwik/index.php:54]
So i cann’t see my stats …
I don’T know why …
Im not shur whitch version i installed.
the piwik.php file says:
* Piwik - Open source web analytics
* @link piwik.org
* @license /licenses/gpl-3.0.html Gpl v3 or later
* @version $Id: piwik.php 568 2008-07-22 22:34:48Z matt $
and the index.php file says:
* @link piwik.org
* @version $Id: index.php 539 2008-06-29 22:05:21Z matt $
* @package Piwik
is there a way getting piwik working again with the old statistics already collected ?
or do i have to delete and reinstall a new one?
Depending on the version you’re upgrading from, it’s often safer to rename your piwik folder, and unzip the new release into a fresh piwik folder. Then copy your old config file over.
Critical Error during the update process:
/www/htdocs/USER/DIR/tools/piwik/core/Updates/0.4.1.php:
Error trying to execute the query 'ALTER TABLE `piwik_log_conversion`
CHANGE `idaction` `idaction` INT(11) DEFAULT NULL'.
The error was: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'idaction' in 'piwik_log_conversion'
Do you recall what Piwik version you were running prior to the update? The log_conversion table was added in 0.2.27, so the 0.4.1 update shouldn’t fail.
Please go into mysql and execute the query:
DESCRIBE piwik_log_conversion;
I need to know if the table exists and what is its structure.
And also execute the query:
SELECT * from piwik_option WHERE option_name = 'version_core';
Im not shure witch version.
i think i installed it in 2008 at the end of the year.
the date_registered from the anonymous-user says: 2008-08-19
Host: localhost
Datenbank: DB_NAME
Erstellungszeit: 06. Januar 2010 um 17:13
Erstellt von: phpMyAdmin 3.2.0 / MySQL 5.0.45-community-log
SQL-Befehl: DESCRIBE piwik_log_conversion;
Zeilen: 18
Field Type Null Key Default Extra
idvisit int(10) unsigned NO PRI
idsite int(10) unsigned NO MUL
visitor_idcookie char(32) NO
server_time datetime NO
visit_server_date date NO
idaction_url int(11) YES NULL
idlink_va int(11) YES NULL
referer_idvisit int(10) unsigned YES NULL
referer_visit_server_date date YES NULL
referer_type int(10) unsigned YES NULL
referer_name varchar(70) YES NULL
referer_keyword varchar(255) YES NULL
visitor_returning tinyint(1) NO
location_country char(3) NO
location_continent char(3) NO
url text NO
idgoal int(10) unsigned NO PRI
revenue float YES NULL
(`option_name`, `option_value`, `autoload`) VALUES
('version_core', '0.4', 1);
