I downloaded and installed the matomo drupal module (https://www.drupal.org/project/matomo)
I am trying to connect my piwik pro to the matomo drupal module.
But, the Matomo site ID field allows me to enter (aproximately) 20 character and my Piwik pro site id is on this form :
xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx
Do you have any idea?
Is this drupal module compatible with piwik pro? or do you know which one is?
My Drupal version is 7.43
Thanks for your help cheers.
