sounds like some sluggish database server.
I’m running piwik with around 6000 sites and only the archiving is giving me some problems as it runs for hours now but the visiting the dashboard or other backend parts works fine for me.
For backup purposes I switched the tables to innodb and I’m using xtrabackup to backup those without service interruption.
[quote=Thomas Seifert @ Jul 6 2010, 11:08 PM]sounds like some sluggish database server.
For backup purposes I switched the tables to innodb and I’m using xtrabackup to backup those without service interruption.[/quote]
Hi Thomas,
Thanks for the info. I’ll look into what our server is. I’m pretty sure it’s a shared package… Which isn’t the best for anything like this anyhoww…
I’ve never heard of InnoDB. I just found their site via Google… How hard is to switch to using InnoDB?
Also… whats the server spec for your Piwik server?
Innodb is a database engine in mysql. Usually you have it installed with mysql itself.
Its easy to switch to it, just an “alter table …” command. Keep in mind, that the database size will nearly double with switching to innodb because of different storage formats.
I got a quite beefy server which is running as the main database server for all my services, not just piwik.
Its a dual quad-xeon machine with 16GB ram and a RAID10 with 4 disks.
PHP is delivered from other servers but piwiks load is mainly on the database.
I think I’ll be trying to get our Piwik install moved here soon. We have a MySQL server we could move to for the database…[/quote]
Hi, I am working with Eric on this.
We now have it on a dedicated server and the database set as INNODB by default so all tables are now in that format, even the ones created by the archiving script.
This seems to have got things working, but we are still unable to access the “all websites” as it just times out and I have it set at 600 seconds.
Should this be the case for a site with just over 700 sites at the moment, this will be increasing though.
disable auto-archiving via the ui and let the archive job run every night.
@matt & vipsoft:
what about disabling “Reports for today will be processed at most every” if “Allow Piwik archiving to trigger when reports are viewed from the browser” is disabled?
Yeah, the all websites panel doesn’t work well with many sites. its simply running too many queries and it will still do that in the future, even with the enhancements if you have LOTS of sites style_emoticons/<#EMO_DIR#>/wink.gif.
As far as I understand the ticket its supposed to merge 6 api requests per website into 1 per website. That might help for < 1000 sites but with 6000 sites its still 6000 queries which is probably slow :-).
Well, sorry if I get it wrong but I’m not planning for the all websites panel for now.
