Has anyone successfully tried Piwik on a Shopify store ?? I am referring to my own Piwik server not the App for Shopify that uses the Piwik cloud.
You simply have to add a Piwik generated Tracking code to the footer of your site and you are off and running.
That is is most every eCommerce platform, blog etc EXCEPT Shopify ??? The Shopify Gurus are not very much help as the just blame Piwik for an unsecured product and try to push you to the paid app.
As mentioned I have had success with this method on 6 other of my sites with no technical support needed … it is just putting the code in the footer… Shopify is very frustrating with very simple implementations as their system is so highly proprietary.
Any GUIDANCE / HELP would be GREATLY APPRECIATED !!
THANKS
Peter
