PIwik not showings IPs
(Miki Pavlov) #1
After upgrading to Matomo 3.5 I’m having some issues with GeoIP2. This is from the error log:
"2018/05/09 00:04:18 [error] 792#792: 10078 FastCGI sent in stderr: “PHP message: PHP Fatal error: Cannot declare class Piwik\Plugins\GeoIp2\GeoIp2, because the name is already in use in /var/www/mysite.com/public_html/plugins/GeoIp2/GeoIp2.php on line 0” while reading response header from upstream, client: 95.180.**.***, server: sysite.com, request: “GET /index.php?module=Marketplace&action=overview&idSite=8&period=day&date=today HTTP/1.1”, upstream: “fastcgi://unix:/run/php/php7.0-fpm.sock:”, host: “mysite .com”, referrer: “mysite .com/index.php?module=Marketplace&action=installPlugin&idSite=8&period=day&date=today&sort=&pluginName=GeoIP2&nonce=88ff70f2978978be7e9126d4fa9861f5”
plus the visitor IP is not shown -
(Lukas Winkler) #2
Please check out those posts:
(Miki Pavlov) #3
GeoIP2 is not available after deleting the plugin. Here is how it looks on my side:
with plugin -
without plugin -
(Lukas Winkler) #4
Hi, I’d recommend you to uninstall the old third-party GeoIP2 plugin and use the new GeoIp2 plugin.
(Miki Pavlov) #5
Thanks for the quick replays but the plugins is already uninstalled. Now how can I use GeoIp2 when is not available.
(Stefan Giehl) #6
You can use the setup wizard below the provider selection to download the latest geolite2 database from maxmind, afterwards you should be able to use the provider.
(Miki Pavlov) #7
The file was downloaded -
and its in misc but still the same:
(Miki Pavlov) #8
Also, I have a cron.monthly script that is downloading the City and Country database each month, so I’m sure that the files are in misc dir.
