Piwik not rendering in chrome or IE
When i try and load piwik in Chrome, i only get a blank white page, no errors. In IE, I receive a 500 internal server error. PHP 5.4.24 and latest version of piwik downloaded today.
Any ideas?
Hi there. please look at your server error log file and then look int he FAQ for the answer.
Hello, same here.
The log says:
09.12.2014 14:34:40 statistik.xxx.de [client xx.xxx.xx.x] PHP Fatal error:  Class 'ComposerAutoloaderInit62ff5c2fbc07919bd7f6c4f44af17302' not found in /mnt/webx/xx/x/xxxxxx/htdocs/piwik/vendor/autoload.php on line 7
Does FAQ 153 apply here?
Thanks in advance,
Daniel
Hi Daniel,
can you try to upgrade your piwik to the latest beta from: Index of /
or: I would like to test early beta and RC releases, how do I enable automatic updates to use these development versions? - Analytics Platform - Matomo
if you still have a problem there, let me know i’ll assist!
Hi Matt,
thanks a lot. I used latest files with old database and it works again!
No matter what was wrong …
Cheerz
Daniel (happy)
I had the same issue when upgrading from 2.8.0 to 2.9.1.
The solution for me was to manually upgrade first to 2.8.1, then 2.8.2, then 2.8.3, then 2.9.0 and finally 2.9.1.
Everything seemed to work fine after that.
Adam.
