I’m new here, and just trying to get to grips with Piwik. I have had a search around the forums and online and can’t seem to find an answer to my query, so I hope it’s okay to ask here.
I have installed piwik on a Hostgator shared server at piwik.domainA.com. I am having a problem getting SSL login to work. I add the line ‘[General] force_ssl=1’ in the config.ini.php under [General], and that indeed directs to the https address.
However, I do not see the Piwik login page at https:// piwik.domainA.com, just a server error saying:
Index of
/cgi-bin/
Apache Server at piwik.domainA.com Port 443
As soon as I remove the SSL line from the config.ini.php file it works fine. I should mention that this domain is routed via Cloudflare (free) which I know has restrictions on SSL, but even when not using Cloudflare this problem is present.
I would be most grateful if anyone can point me in the right direction.
Thanks
