Hi All,
I am trying to create a chart which takes user input and displays the result in a data table.
For this, I have included html table and input fields in the controller file. I can get input in the input fields but I have no clue how to send the input variables to the API.php? I want to receive the variables at API.php and get required data from database and create dataTable array and return it to controller to create the datatTable. Is there a way to pass parameters from controller file when the function in API is called?
For e.g:
$view = Piwik_ViewDataTable::factory(‘table’);
$view->init( $this->pluginName, FUNCTION, ‘MyPlugin.getResult’ );
Can I send the variables while calling the API page from the controller?
Any help will be greatly appreciated.
Thank You,
Anjali.
