'piwik_archive_numeric_2014_12' not found.
Hello. I did an upgrade to Piwik recently and now most of the pages display this error. The visitor log still works, but none of the other stats pages.
ERROR VisitsSummary[2014-12-19 20:57:27] [08786] Failed to get data from API: Sequence ‘piwik_archive_numeric_2014_12’ not found.#0 /home/earrame_vps/seawingdesigns.com/piwik/core/DataAccess/Model.
What should I do to fix it?
Hi there,
to fix this issue you can execute the Mysql QUERY:
INSERT INTO piwik_sequence (name, value) VALUES (‘piwik_archive_numeric_2014_12’ , 99999)
Thanks, That worked. :slight_smile:
Once the year changed, this problem came back. Do I do a similar Mysql QUERY?
that’s weird, can you post here the error message?
ps: yes you can run similar query, but this should 100% not happen!
I already fixed it, so I can’t post the error again. In another thread, I posted a different error that was coming up and you pointed me to a sql query that was posted on git hub. That solved everything. It was pretty much the same thing, but with a 2015 date in it.
I’m still getting this error repeatedly. I’ve done a “INSERT INTO piwik_sequence…” query for about 20 different months, but every time i run the archive script, it seems to come up with a new one.
Is there something I can do to clear this up once and for all?
Hi there,
I have the same problem:
×API returned an error: Sequence ‘piwik_archive_numeric_2015_03’ not found. at Sequence.php:99
Please can you help me, because I need to run my weekly reports for 10 websites!
It’s very urgent to get that fixed asap.
Thanks in advance.
Steven
Hi again,
I just have used your SQL query
and the error message disappeared. Now I am trying to run my reports again…
Greetings
Steven
Hi guys
this bug should be fixed in 2.11.2 version released today. if you still have issue after that, please report a bug in the tracker" Issues · matomo-org/piwik · GitHub
