Hello together,
I use smarty with piwik, all run fine, I got no errors,
but in the admin menu I see nothing.
The script run now over half a day.
Is this normal or is there something wrong?
Best Regards
Andy
Hello together,
Best Regards
Andy
Is seems to be normal, because I got now after over 6 hours the first results.
Best Regards
Andy
If you paste the Piwik tracking code into a Smarty template, then you have to remember to use Smarty’s {literal}…{/literal} tags.
If you have a lag in reporting then you likely don’t have the timezone set for the website. Go to Settings | Web Sites Management.
