have a look at 301 Moved Permanently
[quote=JMETERX]
Matt - any website you select from the drop down bar gives us an error on the page. THe drop down bar is in the upper right hand corner you click it and select another site and it won’t load but the stock one. Looks like others are starting to have this issue as well.[/quote]
Indeed, can you please comment in: 301 Moved Permanently ?
I still have this issue
SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘idaction_category2’ in 'on clause
uploaded the new piwik.js already.
Any idea what to do next?
Thanks Thomas
Make sure that you uploaded all files in core/Updates/1.6-b1.php etc. and then run this quer: 301 Moved Permanently
thanks. that did the trick. is this the way it’s supposed to be – not fool proof?
