Piwik 1.5 RC has been released!
we would really appreciate if you can help test this release which contains many new exciting features.
Download the ZIP: http://builds.piwik.org/piwik-1.5-rc7.zip
To update, simply upload / overwrite all existing files and then visit your Piwik. It contains many database upgrade, so make sure you run update in shell if you have a big database. Update Piwik - Analytics Platform - Matomo
NEW FEATURES
1) Ecommerce analytics
Piwik now has advanced and very powerful Ecommerce tracking. You can enable ecommerce for each website, and then setup Tracking of your ecommerce product views, add to carts and ecommerce orders. More information on the page Ecommerce Analytics
2) JS Canvas Charts (no more flash graphs!)
Piwik now draws graphs using jqplot library, in Javascript + canvas. The graphs have the same look and feel but are using fully open source stack and is more performant!
3) you can now Track Custom Variables per page! (as well as visits)
More info on Custom Variables analytics[/url] and [url=http://piwik.org/docs/javascript-tracking/#toc-custom-variables]Tracking Custom Variables
4) Inline help
Now Piwik has inline help for most reports (next to the report title), as well as inline help for Columns in reports (hover on the column name to see the documentation). This helps understand what the piwik metrics mean. If you have any suggestion on making these docs better please make a suggestion here
5) Custom Logo upload
You can now upload your Custom Logo which will be displayed in the UI, on the Login screen and in the Email reports
6) New Privacy plugin
Now very easy to setup IP Anonymization from the Privacy settings. Also Access the new feature to delete Old logs from the database, to keep your DB size small !
)And more…
See also support for http outgoing proxy: How do I configure outgoing (forward) proxy in Piwik (eg. squid)?
Check out the list of closed tickets for this release for more bug fixes and new features: adding support for windows phone 7 version 7.5 by thirashima · Pull Request #1 · matomo-org/matomo · GitHub
Please post any issue or question in this post, thank you for your help testing!!
