kwikone
(kwikone)
April 25, 2011, 9:49pm
1
After upgrade to version 1.3 (OneClick upgrade) (clicked on continue to piwik) get the following error:
SQLSTATE[42000]: Syntax error or access violation: 1142 INSERT command denied to user ‘’@‘227.7.31.194’ for table ‘htm’
And this exception raised another exception “SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘requestKey’ in ‘field list’”
And, since all tables should have “piwik_” for a prefix where is table htm? and what do I need to do to fix this problem?
matthieu
(Matthieu Aubry)
April 26, 2011, 2:35am
2
requestKey and htm are not Piwik tables or columns…?
kwikone
(kwikone)
April 28, 2011, 7:11pm
3
I did not think they were - at least I had not been able to find them. So… why am I getting this error from Piwik then?
And why after upgrading to 1.3? What can I do to further track this down?
matthieu
(Matthieu Aubry)
April 28, 2011, 10:26pm
4
are you using other non core plugins? try to disable them maybe?
vipsoft
(vipsoft)
April 28, 2011, 11:00pm
5
Must be a really obscure plugin. I just grepped 40+ of them.
