Here you can see https://nimb.ws/OHLDE1
Before this error, there is another one (SetTrackingSource)…
I don’t like this…
Also, I don’t understand why I don’t see the MTM container in the call stack.
Can you share the full Matomo bootstrap code you inserted in your page?
Hi @komir,
Remove the _paq code (the basic Matomo bootstrap code). The MTM code is sufficient by itself, it contains already all the _paq stuffs…
Sorry for my ignorance, you mind removing the whole
<!-- Matomo -->
<script>
var _paq
</p></noscript>
<!-- End Matomo Code -->
code
and only to leave
<!-- Matomo Tag Manager -->
<script>
var _mtm
</script>
<!-- End Matomo Tag Manager -->
Yes, that’s it!
Thank you. I remove it but now not receiving any data
Did you configure a page view in MTM? without it, the container won’t be well initialized. (Note also that the scrolling can be tracked by MTM)
Then can you display (you can do it directly in the forum by pasting the image in the text):
- The MTM preview
- The browser console in case of errors
- The browser network console (filtered on your Matomo server)
I use the “History change” trigger https://nimb.ws/HKhwg9 if you mind that.
Is there a page view tag sent with this trigger?
As you use the page history change, I suppose you are in a single page application, aren’t you?
It is not, seems to me I don’t need that ![]()
I assume need to configure Page view but don’t know do I need to add to “Only trigger when (optional)”
As mentioned, this is optional.
Then no need to set a “when” clause for the trigger.
Thank you. I have it without “when” but still don’t see any traffic
Did you publish the container?
Do you look at the real-time visits log? (or at the visits log of the current day)?
Do you see any error in the browser console when browsing the tracked site?
Do you see any HTTP error in the browser network log?
What do you see in the Tag Manager preview/debug?
Yes, the container is published. On page sources have https://domidona.smarthost.eu/js/container_d1IOub3d.js
Yes I did.
No.
No
Here is link
https://www.konveks.hr/?mtmPreviewMode=d1IOub3d&mtmSetDebugFlag=1
@heurteph-ei
Hi did you get a time to check
Hi @komir
Sorry I was not able to visit the link you provided due to some company restrictions.
Did you find any solution?
(if you want, you can post screenshots instead of links)
