jltest
(jltest)
February 4, 2017, 6:23pm
#1
Hi everyone,
I’m trying to install Piwik 3.0.1 on a shared OVH host. But the check page aks me to add
always_populate_raw_post_data=-1 in my php.ini.
phpinfo() shows me that always_populate_raw_post_data is already to -1.
What can I do ? Can I pass through ?
Thanks.
Lori
February 5, 2017, 7:29pm
#2
Hello
If you have the php-version 5.6, please change to 5.5 oder 7.0.
I had the same problem an the changement could eleminate the problem.
Good luck.
Lori
jltest
(jltest)
February 5, 2017, 8:57pm
#3
Hi Lori,
Thanks for your answer. I read it just after sending the post. So I did it and effectively this worked.
JL Test
jltest@free.fr
